mah deuce
Heath_h49008
102
Kalamazoo/Mich
Wow... I'm only part way through your Pirate 4x4 thread and I am in AWE.
That truck is amazing... The whole thing... the detail of the write up is awesome...
Wow....
Did I mention "Wow?":beer::drool:
SPCWarning
11
Stonewall, MS
"I will not be jealous. I will not be jealous. I wi..."
Isn't jealousy a bad thing? Wow, that is an awesome build! Like Heath, I only got a little bit into your build thread and I'm WAY impressed! Thanks for sharing this!
Jimmy
jesusgatos
on the road - in CA right now
Chassis is sandblasted and primed, and should be getting painted sometime next week. Will be flat-towing the rolling chassis home with a towbar as soon as it's done, and then it'll finally be time to put the new 5-ton MF engine in there, reinstall the transmission, install the new transfer-case, etc. Really looking forward to getting it all back together.
jesusgatos
There's not really going to be a 'final' color combo, as it'll probably get wrapped/re-painted once in a while. But to start things off, it's going to be black (chassis & under-carriage) and white (body).
461
Sandyston, NJ
Please replace those front u-bolts. They should never be reused after they have been tighten down and used once. Nevermind the fact it looks like you had to heat them to get them loose. On such a nice complete rebuild it shouldn't be that big a deal to put new ones on.
