DieselBob
- 13
- 38
- Arnold Maryland
Just wanted to throw that out there in case you may have had the truck running when you where testing things.
With the lights and heater on it drops to 23.1 and holds.What voltage is "even lower"?
Really? It has the info you seek. Though I prefer the copy I am uploading now. The CAD drawing incorrectly lists wire 38 as part of the temp circuit. The wire is actually 33 per the pic I attached and experience in just doing this job myself.I have the CAD Schematic. it is no help...
Yes, one of the #27 wires from the spider harness will plug into the sole pin of the voltmeter.I have the CAD Schematic. it is no help...
Clinto: what does 27 plug into? The voltage gauge is self grounded so only one wire runs to it... Is it off of the spider harness or truck harness?
The loose 85 should go to the Low Air warning light on the gauge board. Older A2 duces did not have it it was a add on and I think standard on the A2C.Thanks to Lavarock I got the wiring for the gauges figured out with the exception of the one numbered 85. On the firewall I found the air buzzer and it has a wire running into it which is numbered 85. Then it has a wire running out of it numbered 85 which is the loose wire that I have no home for.
I still have a generator Gremlin. It charges the batteries sometimes and doesn't at other times... When it is charging it drives the volt meter well over into the red zone, Reading off of the batteries read as high as 29.5 volts and I shut her down; not wanting to find out how high it will go.
Numbers on the Gen are as follows:
A00132AE
NSN 2920-00-909-2483
SN 145848
Mil G 46795E (AT)
60 amp
Reversible.
I finally replaced my broken tail light with the help of my son. While I was re-connecting the right side taillight he wanted "the ratchet so he could do his side". Which wasn't broken and didn't need to be replaced I may add. So I gave him the ratchet and continued what I was doing. A few minutes later he yells "I got it" and I look up and the driver side tail light is hanging from it's harness and he proudly walks over and hands me the bolts. He is three and I didn't know he knew where to place the ratchet. So I got a camera and took his pic for all to see
