Know this:
The resevoir will only have two, maybe three full pedal cycles before it is empty!!!!
It will be the pump of the pedal after you have run out when you find you have no brakes!!!!
Wise words!
As with my own experience, I was on a "short" 150 mile trip in my deuce with a full reservoir and NO leaks when a brake-line fitting (flare) split! The first "pedal to the floor" was...
The second time was...
There was a large truck stop (dirt) parking lot just past the intersection and I pulled in. Pump #3 was...
and that was it.
I rolled around in the dirt, was covered in fluid and eventually called a local NAPA that brought me out a line that I barely worked into place. I filled the system and called
who brought his brake bleeder all the way up there in record time.
Even when there isn't an obvious leak, brake systems are life essential.
Fix the problem before you take to the road. The trip will be much more enjoyable that way!
