AL to FL
pctrans
19
Bradenton, FL
OK Wreckerman.....Lock up the women and children! I'm heading your way tomorrow. Will call you with an ETA on Saturday morning.
If anyone needs something from his area brought back to my AO, give me a call. I should have plenty of room in the M928.
941-650-2525
doghead
4 Star General /Moderator
1,178
Did you fill them with battery acid or used paint thinner?
Lord, I apologize, and be with the starvin' Pygmies down there in New Guinea. Amen
3dAngus
101
Perry, Ga.
Hummm...Are you going up I 75?
I might have an A/C unit where WM might get it to MWMules at the MVPA. Convention in June.
Also one for Patracy which is on the way to WM place.
Tow4
646
Orlando, FL
If Pete has the same kind of luck as he did coming to the GA Rally last year; it'll be easier to drive to the next exit if the CUCV is on the ground when the big truck takes a $h!t. :whistle:
pctrans
19
Bradenton, FL
So far so good. WM must still have Murphy chained up to those batteries. Will be landing at is LZ in the morning to get hooked up. And YES, experience has taught me to leave the rescue vehicle "on the ground".
Gimpy, I just got the tranny repaired on the 1009, so I'm not interested in seeing how much torture it will take.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Under normal circumstances I'd say that Pete was at Wreckerman893's AO getting loaded out but since he's a professional driver, I'd have to bet he's at breakfast. I'm sure Richard and that family of marsupials will post up pics once Pete vacates the AO.
wreckerman893
Possum Connoisseur
15,629
2,053
Pete made it here this morning and was hooked up and ready to go when I got back from an errand.
We did have to air up some tires and add some gear oil to the intermediate axle. It has a leaky wheel seal.......he will be watching it on the way back to FL.
I laid out some tools and moved some stuff around in the shop...maybe Murphy will lay for me and leave Pete alone on the trip back.
Here are the obligatory possum pics.
doghead
1,178
the wheel seal on the truck was leaking but not so much he can't keep up with it.
So, your saying Pete can leak as much as the seal is?
Tow4
646
Orlando, FL
I wonder if the CUCV is going to be rust proofed by the time Pete gets home.
