quickfarms
- 24
- 38
- Orange Junction, CA
What speed are the tires rated for?
Glen is on the money.....you need a pete..600 hp....18 speed....3.55 or 3.o8 rears....cruse at 85-92 mph.....put the duece bed on it....DAS
not really, a 3116 @ 2700RPM will set your teeth on edge.
I know, I did it from MD to MA, almost 500 miles in a single (LOOOONG-a55ed day)
Rarely have the nerve to drive mine over 45, even with 395s - it sounds like something is going to break/explode with the drive-train noise level at that speed.
Edit - oops - i see A3 now - likely runs a bit quieter than an A2 =)
I hope to take my A3 from Atlanta to the family farm in south Georgia multiple times a year. The trip is 240 miles which means that I could make the trip in about 1.5 hours less time (each way) if I could travel at 70mph. I would rather take that time and use it around the farm/river/ponds than to use it absorbing the scenery along I-16 (I have made that trip hundreds of times and there is nothing along that route that I haven't already seen or care to see). To each his own though.
The 14.5 x20 michelin tire is rated for 55 mph stamped on the tire somewhere I do believe. Compund that with the fact that the military ran that tire at a maximum inflation presurre of 45 psi when it is rated for 80 psi max means that an old tire, ran at half inflation for its life before you got it, at 30% over its maximum speed when you are running to your farm doesn't sound like the stars lining up for you to win the happiness jackpotIf you plan on turning an A3 tire at 70mph, be prepared to be a dead man.
What are 395's rated for?The 14.5 x20 michelin tire is rated for 55 mph stamped on the tire somewhere I do believe. Compund that with the fact that the military ran that tire at a maximum inflation presurre of 45 psi when it is rated for 80 psi max means that an old tire, ran at half inflation for its life before you got it, at 30% over its maximum speed when you are running to your farm doesn't sound like the stars lining up for you to win the happiness jackpot
That transmission exists, It's called the 1545, It came installed in my A3 and after the "flush" it is a sweet tranny.I'd be down for trying a lockup converter if one exists.....
That is cheaper than buying a good 6 speed Allison3053 trans $200
gear set $1300
clutch $300
flywheel $200
driveshaft $150?
linkage etc $150?
do it yourself you could only have $2500 in it.
does it increase the value of the truck?
i know of one being done now so we will see how it goes.
tom
at least for around HERE, your numbers look very low.3053 trans $200
gear set $1300
clutch $300
flywheel $200
driveshaft $150?
linkage etc $150?
tom
Where would you put it?How much do you figure a gear splitter would be?
I saw one online but it may have been on an A2, now that I think about it. I'll look tonight and see if I can find the picture again.Where would you put it?
They are the size of a transmission and are obsolete
To make the truck go faster, just install 3 overson 4.90 axle gear sets and your golden. They go for $1200 ish each. That option is still cheaper than a tranny swap.
opcorn:
