2012 Ga Rally parts wanted/for sale/swap thread
pctrans
19
Bradenton, FL
Did that once myself. Jacked around with a slim-jim for awhile till.......
aua Roll the back window down Dumba$$ aua
bigboy44
Ava, MO.
I have a gondola cab that ZiggyO has committed to purchase, I am in Covington, La. . He said he would like to have someone bring it to the Ga. rally. If anyone is interested please contact him and please let me know asap as I will be MIA for a while. Any compinsation will be on his part not mine, just trying to help.
Thanks
748
Woodstock, GA
For a while I have been looking for a complete winch assembly for my M35A3 but I haven't had any luck finding one. If someone has one available please let me know. Otherwise I am going to start making plans to install an electric winch. In that case, does anyone have the frame extensions that I will need?
I was also hoping that someone would have mounting brackets for a 12v alternator in an A3. I would buy this as a complete assembly if all of the parts are there or I could buy just the bracket if that is all that you have. Next time someone fabricates one of these brackets please keep me in mind.
michigandon
82
Wake Forest, NC
Try poking around in a few heavy truck salvage yards that have civilian commercial trucks with Cat 3116s in them. I would think that you could find what your looking for there and easily adapt it to the 3116 in the A3. Just a suggestion.
748
Woodstock, GA
I don't know if we are on the same page.
To clarify:
I am talking about a custom made bracket to hold a 12v alternator above the 24v alternator in a M35A3. I have seen a few members fabricate and weld these together and was hoping some one might have an extra one or would being willing to make one.
However, I do appreciate the advice and I will look at my truck this weekend to see if your suggestion would be feasible.
123mack
11
Jemison, AL
I have 2 MEP 018 generators to part out. This is the 10KW generator with the 4 cyl gas motor. Probably could make one good one out of both.
bigboy44
Ava, MO.
Mr. Tim, yes it can be taken apart in 5 pieces. It is pretty big and heavy as it is. Taking it apart should pretty easy and would make it a lot easier to handle.
AMGeneral
115
Connelly Springs, NC
limited space on the trip up so if somebody wants something let me know to pack it!
prices are NOT firm... trades welcome!
m105 fibereglass racks front & rear $30.00 each
m105 wood side racks $25.00 each
m105 bows new wood, old and just corners $10.00 each $5.00 corners
m105 cover grn $25.00
5 ton center & jack drive shafts $ 50.00 for both
deuce spare tire bracket less cable $10.00
2-3 used duce 3 color cargo covers $25.00each
gp small tent no poles ( bad screen) canvas in good shape $30.00
cucv steering column $25.00 (swapped to a tilt)
M1009 swap bar with ends $15.00
M1009 rear bumper hitch bracket with trailer plug no pintel $10.00
pup tents shelter halfs like new shape $5.00 half
pup tent poles (limited quantites) $1.50 each
deuce starter-was told you can reclock the nose for use on a 5ton $150.00
fiberglass uprights for deuce/5ton bed $10.00 pair
drop side corners $10.00pair
deuce/5ton cargo wood bows $15.00 each
M1101/02 roof support (cover)poles/bows 3-- $20.00 set
M816 rear winch lead chain & hook -Like New- $35.00
maybe more!!
Vinny
Vinny,I'll take the 816 rear chain and hook,mine is streched on the M62A1.
mikev
71
Culleoka, TN
I'll take these...
maybe more!!
Vinny
Vinny,
Pencil me in for these CUCv parts:
What's a swap bar? - sway bar?
Thanks,
Mike
