Official 2012 SS Ga Rally Info thread
Woodstock, GA
Firewood for the Rally
I was off work yesterday and took advantage of the wood that the Georgia Power right of way crews left across the street from my neighborhood. There was plenty more but I couldn't even lift the pieces if I was twice my size. Could have used a log splitter. If anyone close by wants to split it let me know an I will tell you where it can be found. Another tree crew was out there today taking a huge oak down for a development. Hopefully they cut it up a left it like the GA PWR crews did. Also, the stack of wood pallets I'm holding at work is probably 10 feet tall now. :beer:
2,420
The CAMO Crew will bringing a deuce load of wood as well...specifically Troy cause he's been cutting down/up trees and wants ta get rid of em!
I just hope I don't run over a tree on the way to the rally this year!:oops:
The last one cost me about 2K in parts and Troy/Tony did most of the replacement work!:shock:
RIDDLE1
Americus GA
Fire ants!? Well it looks I will make sure to pack the Epi-Pen. Of all things, I'm allergic to freaking little bitty ants.
Are we going to start of Convoy thread or did I miss one?
RIDDLE1
Americus GA
We need to find a VT item to burn!
EMD567
Driver for the Ga Mafia
47
Aiken SC
I also have a stack of pallets at work for the firebugs in our midst.
swiss
762
Oakwood, Ga
It sounds like we will have enough wood to burn for 3 months and not 3 days. Now what happens when it is 80 degrees on Wed-Saturday????? Who is bringing 2000 lbs of ice?
2,420
Temperature has NOTHING to do with the bonfire!:shock:
Well...OK...if it's cold at night, the fire helps...but if it's hot...the fire helps to..get it??:beer:
swiss
762
Oakwood, Ga
PB I dont get it :(
I hope it is colder, I am done with summer in Georgia for 2012. Bring on the cold weather.
1,127
Thank you all for taking the time and effort to bring firewood. We have the option of having multiple campfires this year, one in the major vendor/display field and another in the camping area, so it will be put to use.
is the fire ant problem being taken care of?
I do not know how bad the fire ant issue will be this year, since it's a new field, but I think it will be a lesser issue than last year.
However, anyone who wants to bring fire ant countermeasures, is welcome to bring the pain. Fire for effect, Ridley!
There is a convoy thread for people coming from Florida and South Ga., there is a link in the first post of this thread. Check it and see if it fits your needs.
I doubt there are enough people coming from South Ga that aren't hooking up with the Florida folks to justify a separate convoy thread, but if enough people ask, I will create it. I am easy going that way. :D
zout
154
Columbus Georgia
Good possibility of attending for what its worth - just letting ya cherry freaks be advised is all.
PB - best way to explain the bonfire - its the quickest way to get alcohol out of your system - burn it off. I know there has been a couple folks in the past wanting to fire walk the pit - but once you see how big the fire is I do not suggest attempting it - but EH - always up for something new to watch.
Deb was wanting to take a Sat after I get out work here soon to head out to DT grounds and check out the new area and kind of possibly get out bearings straight (nothing worse than out of alignment loose bearings) as she was thinking with those coming really early this year to locate and then head out there that previous Sun to drop and steak out an area as well as an area for the CAMO crew that we have done in the past for them to give them room to manuver.
IF its not this Sat it will probably be the Sat of the 15th - run over in the POV and investigate.
EMD567
47
Aiken SC
Zout, the offer still stands. It looks like Ferro and I will be there friday, the 5th of OCT. We plan to get a spot for Neil, you and the guys from CAMO. The rest of the crowd can fill in as they show up. I know we will be back along side the fence, where we won't bother the rest of the rally with all the whooping and carrying on........:driver:
EMD567
47
Aiken SC
Plus I need a lot of room to turn the Long Easy around- 1/2 an acre or more.............:mrgreen:
CARNAC
The Envelope Please.
619
Corpus Christi, TX
Folks it's starting to look REAL bad for me making it. I have to go on a really loooonnngg plane ride on the 14th and I can't leave from ATL. Unfortunately, it looks like I'll be in the southeast again at the end of Oct.
There's an idea, just change the dates to accomodate me, LOL.
EMD567
47
Aiken SC
I would inform "them" that you can't leave until the 20th, because you have to have your "cherry" shot, or you could die. Of course, you have to be able to say this with a straight face, or you are doomed.:mrgreen:
