anything 1009's are notorious for?
timo247
Bulverde,TX
I might be getting this M1009 in texas and I just want to know if 1009's are notorious for anything. like weak axles or something of the general sort. this will be my first vehicle and I don't want to figure out something that is known in these vehicles to fail easily. thanks!
donalloy1
Martinez Ca
Lots of Odd looks in COCO County! Other than that. Pretty staight forward. Most of the areas that cause Headaches are covered well here. Tune in and you will be good to go! We love ours! Take kids to School and me to work everyday unless I am down for service. Not unlike any other vehicle in my Garage.
Looks better to!
The Pawnbroker
Annapolis, MD
If there is a thread that lists the most common repairs (preventative maintenance) I would appreciate a link to it as well.
I'm having an electrical problem right now. In my forum search, I found a number of posts regarding replacing the starter solenoid with a better quality unit from Napa. It looks like a somewhat common problem that's easy to replace and will prevent a fair bit of damage from happening.
CycleJay
Marietta, Ga
Hello Timo,
Yes, the first thing you need to do is the "Doghead starter relay mod".
Because the stock starter relay has been known to stick, and burn out starters,
fusible links, alternators, etc.
The "Doghead starter relay mod" is a MUST do, before you do anything else.
As it is one of the most expensive and damging problems that can happen,
if you do not do it. Trust me I speak from real life experience with my own M1009.
Another suggestion, add a 24v solargizer to keep both batteries topped off..
Anything else you want to know, and I have learned alot since I got my M1009,
ask the guys here, or feel free to PM me any time.
I would be glad to help.
Good luck...
Tanner
11
Raleigh, NC
Welcome to Steel Soldiers!
Ahh, yes... the first vehicle at 17 - you couldn't have picked a finer ~ 25-plus year-old vehicle to get for use as a vehicle repair training subject!
Read all the CUCV threads. Especially the one's dealing with 'So You Want To Buy A CUCV and Have Many Questions, But Were Afraid To Ask or Use the Awesome Search Feature'. And get a TM (Tech Manual) on the CUCV.
And buy your local GM Dealership or generic parts house guy a case of cold fermented malt beverages - you'll soon get to know each other well.
http://en.wikipedia.org/wiki/Commercial_Utility_Cargo_Vehicle#General_Motors
It's also good to develop patience & a thick skin for busted arms, hands & knuckles on repairs.
Again, Welcome!
'Tanner'
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
AHA! This is the thread that I was replying to at the moment that the site went down!
Ok, hopefully this doesn't crash the site again:
I'd say electrical problems, especially in the instrument cluster where a bad bulb contact can make parts of the truck quit working in unexpected ways.
:beer:
combatmech
Carrollton, Texas
:ditto: Dont let the fancy military 12/24 volt system scare you. Read the TM's, and search here on SS. Avoid trying to convert it to 12 volt.....It already has a fickle electrical system if not maintained properly.
Be ready to spend about a grand right off the bat. Belts, hoses, suspension, filters, fluids, brakes, etc.
It is a 25+ year old vehicle that may or may not have been cared for very well.
Hope it comes with a fresh TX inspection. Hope you were able to inspect it. Hope it hasn't been electrically butchered.
Remember.... The TM's and the search feature will guide you to CUCV enlightenment.
doghead
4 Star General /Moderator
1,178
Annoying Ron.
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
I forgot to mention the standard wisdom for the M1009 and its relatives: If it's electrical, clean it. If it's rubber, replace it.
I also have developed a deep and abiding hatred for the rear window mechanism.
I don't mind the power train at all. I haven't driven my CUCVs much yet, but it's nearly the same power train that I'm used to from my HMMWV.
The electrical system is the illegitimate offspring of an early 1980s GM 12V civilian electrical system and a 24V NATO electrical system. Expect some headaches there, and then have fun with a nice green daily driver once you work out the kinks and learn its idiosyncrasies.
:beer:
gungearz
northwestern indiana
Welcome to steel soldiers... The only thing I hear everyone complaining about with the M1009 is that THEY ARE TO SMALL. Other then that, there as good as any used vehicle. They all have individual issues. Some are lemons and some are flawless... But none are the same.
The Pawnbroker
Annapolis, MD
CycleJay and doghead. Would you guys (and any others of course) please read my thread and see if what I'm describing is likely to be related to the starter relay problem? I'm planing on doing the starter relay fix tomorrow and seeing if it will turn over. I did hold the start position for a bit while I tried to move the shift lever around. My first thought was that it was a neutral safety switch problem because that's what it seemed like to me.
Thanks very much.
http://www.steelsoldiers.com/cucv/94661-my-first-real-problem.html
timo247
Bulverde,TX
thanks for all the very informative replies and I would like to know about this doghead mod? I know about the solargizer and It will be an addition to the truck. luckily I have mkcoen near me to help me with problems on the 1009. specific parts that are known to fail would be very welcome as I would want to have a replacement for when I buy it.
Tanner
11
Raleigh, NC
jw4x4
Dayton, Ohio
09's are notorious for excellent fuel mileage in a full size 4x4. Plenty of room to seat 4 adults comfortably. Availability and affordability of parts. Endless options for customization. I really love mine, esp. as a daily driver.
