Keith_J
- 1,323
- Schertz TX
I am the new owner of a M1031 Shop Equipment, Contact Maintenance truck and being in Central Texas, AC is a great idea. Hacking and chopping plus the expense was something I would rather avoid so I have been thinking...
This truck already has power lead to the SECM box, a 4 AWG 24 volt lead which will power a 2.5 kW inverter. This will easily power a 14,000 BTU portable air conditioner which only needs a 4" vent outlet (for hot air, heat rejection). This can be out the quarter vent window.
14,000 BTU is small, considering the heat load of the cab (most cab truck AC systems are 20-30k BTU/hour) but it beats roasting. And it is multiple use, I can see using if for camping etc.
Yes, I already have the inverter since it fits my generation mix (MEP-002A plus the SECM's 12 kW PTO powered unit). And connecting the inverter to the truck is easy with the existing wiring.
I have looked at the Whynter ARC-14S as the best unit. It has condensate evaporation, meaning no issues with condensate tank. The short run to exhaust should help with efficiency as these units are rated with minimal hose lengths.
