gungearz
- 4
- 0
- northwestern indiana
So does this mean everyone has to spoon with gimpy while we get our ass hairs burnt off just trying to stay dry...?
Was not sure if he was coming or not because of certain issues that are going on between him and a few members.Indy 4x4 will have a shower setup and Ill be supplying the water from the buffalo. Ill have a pump the kids could use. Just need a truck to plug it in to. And if we empty it will just refill from the hose at the office. I try to keep the inside clean for drinking water.
Just install a dry sump oil pump and put tires on the top side too... It'll be fineBut then when (yes I said when, cause we ALL know he can) he turns the truck over it will create a huge mud whole.........
I used to work at a place that did insulation work. We used to steal a 6mil roll of poly, 200ft long and have a blast on the weekends! You have to make sure the dumb drunk that thinks taking the dog on a "slip and slide" is a good idea, way far from it.Let me see if I can get a pump work. then we can pump out of the pond, up the hill and make a real slip and slide.
Little afraid to ask, but why is a dog on a slip and slide a bad idea? Do their claws rip it? Do they poop on it?I used to work at a place that did insulation work. We used to steal a 6mil roll of poly, 200ft long and have a blast on the weekends! You have to make sure the dumb drunk that thinks taking the dog on a "slip and slide" is a good idea, way far from it.
It simply does not work.
I would think that the dog would go crazy- they don't handle movement other then what god has intended for them.Little afraid to ask, but why is a dog on a slip and slide a bad idea? Do their claws rip it? Do they poop on it?
Lube, have to have lube! It will be like mythbusters then. Launching people (drunks) into the pond.So let me get this straight..........sparky's pump, gimpys plastic.........and a drunk is all we need for a slip and slide?!?!?!?
I think there will be plenty of drunks at haspin!!! And if I am also reading it right, as long as a DOG is NOT involved...........it will work? How about a pig? I know where one should be........
Got to love Web tvAnd for anyone that don't know... That was posted with his TV cable remote control...
And Heat Stroke or Frostbite! haha!Haspin has 2 seasons. Mud or dust.
