- 456
- 0
- 16
- Eustis, Florida
Hey guy I think I have a head gasket blow out... what do you think? So the other day i realized that I was leaking oil but it only leak after I ran it at full RPM. However when the truck was at Idle it was not leaking. So i was having trouble founding where this oil leak was coming from. I went out there tonight trying to figure out what it could be. Then I notice a pattern of the oil on the engine block. I notice that the oil spry was heavy at the front of the motor, and that it fade out to the rear of the motor. Then I look at the bottom of the hood and saw the same pattern. So I established that the leak was coming from the front part of the motor and the fan was blowing it back to the rear of the motor. So after looking at the fuel and oil lines and seeing that nothing was leaking. I went ahead took a closer look at the block and this is what I found.![4.jpg 4.jpg](https://www.steelsoldiers.com/data/attachments/295/295010-ee9bc794a10db7ce6bfa8801a258656f.jpg)
![1.jpg 1.jpg](https://www.steelsoldiers.com/data/attachments/295/295004-2a726dae1732eb525c20c56c16ec3292.jpg)
![2.jpg 2.jpg](https://www.steelsoldiers.com/data/attachments/295/295006-8dbcdf52cf555d26c39d6524cebfe1b7.jpg)
![3.jpg 3.jpg](https://www.steelsoldiers.com/data/attachments/295/295008-e1634dafe998de3fd59b0a1191ff4b3c.jpg)
![5.jpg 5.jpg](https://www.steelsoldiers.com/data/attachments/295/295011-7752f3714d344ad8cc44e1e7f9ea2716.jpg)
![6.jpg 6.jpg](https://www.steelsoldiers.com/data/attachments/295/295013-9da3fcf0ef7d411074ddfbc9393c1104.jpg)
![7.jpg 7.jpg](https://www.steelsoldiers.com/data/attachments/295/295015-39dc242d69871e8c5125dbc3d66fc324.jpg)
