Whale oil
RobM36A2
9
The Netherlands
To come back on the coconut fuel.. in a 3rd world country, don't know wich one, they make fuel out of these things..
On topic: I am considering Tea Tree Oil to put in the tank :idea:
zout
154
Columbus Georgia
Wonder how whale oil would work to paint an mv ??? sure would rust proof it for a while. Looks like everything else has been tried why not fuel and paint with it at the same time.
svd dragunov
grants new mexico
If you could find it. It would work great. Just watch out for angry hippies!
As to coconut oil, it has the viscosity of lard at room temp, so heating would be required.
swbradley1
Modertator
1,759
Dayton, OH
Not much heating because I have a jar of it next to my chair at home to rub on my cat's back for a wound. It melts at skin temp.
Shove your hand into the tank to melt it, pull hand out of tank, wipe your hand off then drive away.
Junglemist
Belize, Central America
The natural melting point of coconut oil is actually extremely variable from "nut" to "nut".
Here in Belize coconut oil is locally produced. A row of containers of coconut oil on a shelf at any local grocery store here will range in consistency from a liquid to a lard-like substance at room temperature. Multi-fuels like liquid coconut oil as well as Cohune Palm oil. With the variable carbon build-up issues associated with most vegetable oils.
There is a story locally of a logger in Guatemala who has a multi-fuel 5-ton that he runs deep into the jungle for logs. He uses diesel on the way in and then crushes Cohune Palm bunches as he goes. He runs his truck off Cohune oil until he leaves the jungle.
trukhead
dane/wi
Very Cool! ThankYou![thumbzup]
svd dragunov
grants new mexico
The natural melting point of coconut oil is actually extremely variable from "nut" to "nut". Here in Belize coconut oil is locally produced. A row of containers of coconut oil on a shelf at any local grocery store here will range in consistency from a liquid to a lard-like substance at room temperature. Multi-fuels like liquid coconut oil as well as Cohune Palm oil. With the variable carbon build-up issues associated with most vegetable oils.There is a story locally of a logger in Guatemala who has a multi-fuel 5-ton that he runs deep into the jungle for logs. He uses diesel on the way in and then crushes Cohune Palm bunches as he goes. He runs his truck off Cohune oil until he leaves the jungle.
The stuff i have is the consitancy of lard at room temp. What does he use to crush the cohune?
doghead
4 Star General /Moderator
1,179
zout
154
Columbus Georgia
Back in the day, NASA used whale oil as a lubricant in their space program, including the ROV (Remotely Operated Vehicle) for expeditions to the Moon and Mars. Fast forward to the future and whale oil is still being used to lubricate spacecraft such as the Hubble space telescope and the Voyager space probe. Apparently spermaceti--or Sperm whale oil--doesn't freeze in sub-zero temperatures (quite important given space's super-chilly temps) and man hasn't yet found a suitable substitute for the natural lubricant.
2,464
The only experience I have with whale oil is that time when me, Bertha, and Beula Butts got that room at the Holiday Inn and....oh wait...wrong forum...sorry.
