emr
- 25
- 0
- landing , new jersey
There sure is wet and dry torque, But in a wheel stud this is simply put thinking WAYYYYYY to much
NOT if you are OVERSTRETCHING a stud, as this is what is keeping the wheel on and the truck off the ground.There sure is wet and dry torque, But in a wheel stud this is simply put thinking WAYYYYYY to much![]()
Check out this link from NY: https://www.google.com/url?sa=t&rct...=Rd4CxICIhIGE5YvM5dxNrA&bvm=bv.51156542,d.b2IAnti Seize is not a lubricant, read the container. No DOT in NY State has ever given me trouble about anti seize on my lug nuts... either Budd or Dayton style. If you are worried, don't anti seize the thimble, only the outer nut, now no problemo. Gringletraube pretty much has the story straight, He and guys like myself have pretty much been there. JT out
I have hammered on my lug nuts with a 3/4" impact for a good while before I realized I was going the wrong way.....whoooops. Never broke a stud though. My experience with broke wheel studs tells me when they break they were already on their way out. Unless of course your using extreme overkill. Such as said 3/4" impact on a chevy half ton lug nut because the idiot at the tire shop cross threaded it.I have to commend you for posting that you made a mistake. IT happens.
I can't imagine what it took to break a stud though....
This is the Internet, please don't throw facts up here as it will confuse some.The internet is amazing,
The actual force experienced by the stud is given by the formula:
F=T/([P/2pi]+[uT*rT/cos a]+[uB*RB])
F=tensile force on stud
T=applied torque
P=thread pitch
uT=coefficient of friction between threads
rT=radius of thread midline
a=30 degrees for common thread
uB=coefficient of friction for the bearing surface under fastener
rB=radius of bearing surface midline
Adding lubricant significantly reduces uT and uB, resulting in larger F for a given T.
True. Adding lube increases the load on bolts at a given torque.
