Merc1973
- 38
- 28
- Sykesville, MD
Or we can cut out the rust and do it right...All kidding aside when I got to fix anything on mine it will be done the same way the military did. They weld patches over the rusted out spots and paint it.
Did you search?I thought there was a good thread out there showing what's involved, but I can't find it now.
WOW ! I think you just covered more than the kids learn in two years of vocational schoolI've been doing bodywork and paint on antique vehicles for almost 30 years and here's my on rust patches.
Welding in patch panels isn't all that difficult but a couple pointers to help make it a lasting repair.... cut out any rot that you can and sandblast any remaining rust. Although it is much more difficult, try butt welding wherever possible and avoid lap welds that can trap moisture if they can't be sealed from the back side. Continuous weld beads will warp your sheetmetal and probably cause blow-throughs. Do small stitch welds, but continue stitching until you have fully welded the perimiter. Spot welds with space between them will allow moisture to penetrate through from the back. Always use a non-porus filler such as Duraglass or Allmetal for your first coat over the weld seam, never put regular lightweight bodyfiller directly over a weld seam because any moisture that might come through from the back side will be absorbed by the filler and cause more bubbling and rust at the weld seam. Lastly, whenever possible, seal the back side of the patch with a coat of duraglass, seam sealer or other rust inhibitor to prevent moisture from coming through from the back side. Never put undercoating directly over bare metal without priming and painting first! Avoid using lacquer based primers, they shrink over time and absorb moisture like a sponge if not topcoated. Use a 2K epoxy over bare steel and a 2K urethane primer/surfacer on your finished surfaces before paint.
