Today testing:
The security light was not on but I did the 30 minute relearn procedure anyway. No start.
Checked fuel pump. While I didn't check the pressure, the quanity was good. Also drained about 1 tablespoon of water from the filter.
Checked the voltage to the fuel shutoff. 12v at the solenoid with the key on. Clicks. I also tried hot wiring it directly to the battery. No start.
Removed the check valve on top of the IP. No flakes and was clean. However I did drop it under the intake. Now I have to find my magnet to fish it out. On the 6.2L NA you can fit your arm under the intake. The 6.5L TD you can't.
And I chewed up the negative lead on my multimeter. Radiator fans tend to do that.
Off to read some more.
