Reaper651
- 1
- 0
- Menifee, California
Hey All,
Had enough of trying to search for it. I'm getting a 1971 M35A2 with the LD-465-1C(non turbo) engine. There are a lot of threads on here about how to disable/bypass the FDC and if its worth doing. I have also read that it helps with mileage and gives you a bit more power. Problem is, most of these threads are all geared towards turbo charged 465's. My questions are, on a NON turbo charged Ld-465, does the FDC ever have problems, is it a good idea to bypass it but set it so it wouldn't be that hard to hook back up and is it true that you will get a little better mileage and a little more power if its bypassed especially with a non turbo engine? I figure if you give it more fuel, its goin to need more air. I was thinking to bypass it because I will only run Diesel through it and it makes no sense to me to run it through the FDC but I definitely want to be able to hook it back up if I had to.
Also, is it possible to put a turbo on a regular LD-465-1C, or has the turbo charged version been changed to handle the increased manifold pressure? Is it worth doing?
Thanks in advance.
Thanks in advance.
