after market radiator and fan
These are the part numbers I used. Flex a lite 416 - 16" standard rotation fan (puller)
SUM 380425 alum. cross flow radiator.
flex rad hose dac 81381
curved rad hose gtr 60376
curved rad hose gtr 60762
Yes the radiator is shorter because it is a cross flow the stock rad is down flow. The capacity was reduced by about a gallon and a half of coolant but the huge expansion tank on top of the stock radiator can account for most of that. The new rad has more fins per sq in. If this radiator can cool a 400 hp street hot rod it will cool our 140 hp trucks. As far as the hoses I had to cut and adapt them but it was easy. The mounting brackets are re worked stock ones. I also still used a 7 psi cap with recovery tank so I can keep an easy eye on coolant level.
As far as the gap below the radiator I filled it with a sheet of aluminum I had laying around. Should keep air from going around the rad.
