rustystud
- 2,806
- Woodinville, Washington
I'm starting to install my spin-on fuel filters I bought. I did not want to use the factory copper line since I wanted a field repairable type of hose. I decided to use the Teflon PTFE with stainless steel wrap hose. I know it's pricey, but very durable and repairable. I could have just went with a "DOT" poly hose like most over the road riggs use and also our busses, but I wanted something that could take a hit, and very hard to cut through. I also changed the routing of the hoses. I never liked the fuel hose just under the radiator like it is. Here is some pictures of my water/fuel filter. I mounted it so that I could change the filter sitting on my "NAPA" roller stool . As you can see from the pictures, it's mounted on the frame of the bed just above the fuel tank. I plan on keeping this rig for awhile, and pretty soon I won't be able to crawl all over and under this truck, so make it user friendly now ! Next I plan on installing the primary and secondary fuel filters. I have also replaced all the poly hose on the return lines and fuel pump.
