RustyM923
- 7
- 18
- California
Thank you, Will.
I'll keep an eye out for one (or one to borrow)
-Tom
-Tom
They are under the drivers side dash and are inline. 15a and 3aWhere are the fuses located for the ABS
The ABS ECU is up above the center axle on the relay assy.Where is the ABS ECU located? I can't find it anywhere in the 4 volume TM pdf.
It's not the same thing as the Protective control box (PCB) is it?
I'm having the same symptom. 15A fuse under dash blowing as soon as I turn the switch, ABS light constant on.
eta: Well, they're definitely not the same thing. Went ahead and took the PCB out and took the cover off. It's just a couple of big fuses and little fuses.
Thanks, I don't think I would have ever found it. I was going crazy trying to find it in that mess under the dash with flashlight.The ABS ECU is up above the center axle on the relay assy.
