acesneights1
- 22
- 20
- CT
This will be a work in progress which I hope to get stickied as too many people have lost motors due to being unprepared for a runaway.
Runaway is when you cannot shut the engine down and it keeps gaining RPM until it self destructs. I lost my motor to it. So have other people recently which is why I posted this.
There are a few reasons why an engine can runaway but the most common is improper installation of the Fuel control group after doing work on the IP. Another possibility is it running of it's own oil from a blown turbo seal and lastly I have heard of the Flame heater equipped trucks possibly having a malfunction. I cannot confirm that.
See these links:
http://www.steelsoldiers.com/showthread.php?125810-Runaway-multifuel-today
http://www.steelsoldiers.com/showth...blem-with-my-new-Deuce-need-advice&highlight=
So the links I provided cover the Fuel control group and the turbo seal is basic diesel knowledge so I'll skip that stuff and concentrate on being prepared for a possible runaway. It took less than 2 mins for mine to self destruct although there is question whether it had already been damaged as the clutch was smoked to the point the truck would not move.
First off I strongly suggest removing the rubber hose between the turbo and the intake and having a piece of wood ready to choke it there. I tried to choke mine at the turbo intake and it still stayed running. Also have a good sized CO2 fire extinguisher ready to spray in the intake.
Have another person in the truck ready to stall it in gear. It will take combination of steps, not just one to kill the beast. A runaway multifuel can smoke the clutch in seconds. Trust me on that. be ready to unplug the lift pump at the tank and disconnect the fuel line. Make sure the line comes loose easily and have the wrench ready to do it.Seconds count.
If anyone wants to add to this. I have worked on old 2 stroke Detroit's that ranaway and I was able to choke them down much easier. Honestly I never felt so helpless watching it die.
See these links:
