Runaway multifuel 6/20/14
roscoe
Spencerville, Indiana
Perhaps practicing an emergency shutdown would help some gain comfort from this concern.
Adding an air butterfly shutoff would be a nice modification, if your worried about run aways. (mandatory in some sanctioned events for diesel powered trucks and tractors).
Having experienced this runaway up close and personal, it's not something I want to do again. A quick shutoff like the butterfly valve would be well worth it just for piece of mind, even if it never occurs again. There would be no way I could have got that mushroom off quick enough to do any good had I not done so as a precaution.
roscoe
Well, just doing a visual inspection of the engine all around, I see no holes, no dents in the valve cover and everything looks "normal" for the deuce. Would it be likely that the head gasket blew and spilled out oil. Like I said earlier, I know some fuel got into the oil because the crankcase has too much in it. What would be the next best step to take. Should I see if it will turn over?
RAYZER
58
sanford/florida
A compression test would tell alot.
Triple C
NAPOLEON MO
Make sure that isn't coolant in the oil. If mixed well it's hard to tell. Check out your coolant system before you try and start the truck. I'm with RAYZER, do a compression check.
boogy886
Texas
I think that is a good idea you have there Reaper, using a CO2 extinguisher with an emergency kill switch. That could be a Life (engine) saver !
I've been thinking about doing this for a while, 5 lbs should do it. You can get a 5 lb CO2 tank used for beer kegs (I've got a couple laying around) off of Amazon for ~$69. This could be plumbed into the fording kit port, if you do not have a fording kit, right? Then you're a quick valve-turn away from an emergency shutdown.
Hope your engine isn't toast! But, as others have said, things could have been worse! Glad you're okay!
cbear
Cincinnati, OH
While trying to get an old extinguisher recharged, I learned it can be hard to find anyone willing to do it, unless you have a business. Also, your cylinder will need to be within inspection dates. Just an FYI.
boogy886
Texas
Another advantage to my technique, some of the larger Liquor Stores with a "brew your own" department can fill these tanks for you. And, because I live in small town that doesn't have one of these stores, I actually get the guys at the local paintball arena to fill my CO2 tanks. But, your cylinder will still have dates on it.
swbradley1
Modertator
1,607
Dayton, OH
You might be able to get tanks filled through your local fire department.
Most pressure (if not all) require visual and hydrostatic testing at certain intervals. SCUBA tanks are 1yr on vis and 5 yr on hydro.
John S-B
951
Ostrander, Ohio
Most fire depts. DO NOT refill extinguishers. Look in the yellow pages or the internet for companies that do fill them.
Jeepsinker
368
Dry Creek, Louisiana
Anyone that need extinguishers filled can do so through me. I have an extinguisher service a couple of miles from me owned by a friend and he has very reasonable rates.
Squirt-Truck
Master Chief
162
Marietta, Georgia
I understand the concept of using CO2, but, has anyone considered the number of cubic feet of gas needed to completely displace the O2 being pulled into the engine and that this flow will have to continue until the rotating mass comes to a full stop or they will just re-start?
Just a thought......
ke5eua
40
Baton Rouge (Central), LA
Halon, put a bottle in the cab and run the lines to the intake right at the engine.
Will be more expensive but halon would be the ideal solution in this.
acesneights1
21
20
CT
You most likely dropped a liner. Do a compression test. Here is a picture of the tool you will need. It is an adapter made by Snap On for doing Mack engines.
roscoe
Thanks. That is what I was planning on doing next and wasn't sure what I needed. Haven't had any time lately to do much with it. I did drain out about 2 gallons of excess oil/ fuel mix, reassembled the fuel shut off and cranked the engine, with the fuel off, and it turned over fine. Also plugged the forwarding hole with a 7/8 th inch rubber plug.
QUADJEEPER
Winter Springs, FL
I just used a bolt and a couple of washers, didn't want it to be sucked in. I tested it last weekend after making a quick release for the intake mushroom and a block off. Major suction even at only 2k RPM. A rubber plug would get sucked right in, I'd think.
