rustystud
- 2,806
- Woodinville, Washington
Here are some more pictures of my install. I used a .25" plate of stainless steel I had laying around to support the filters. I drilled the 3 bottom holes for mounting to the block. I also removed the studs from the block as they would have hit the filters. The upper holes are for the filters. I wished I had the filter bases that would allow a pipe to connect them together, but I couldn't find them, so I had to use a nylon hose. The one thing I had to make sure of was the relief valve. It is a 60 psi relief valve. The one I used is "PRV70" diesel pressure relief valve from www.murcal.com , part #55700268 .
I will run new fuel lines from the injection pump to the filters after I perform the FDC bypass. I will also be making up a new return line out of the "PTFE" stainless hose I have.
