spicergear
- 28
- 0
- Millerstown, PA
If you've not heard of this, don't feel bad. If, however, hydro-boost rings a bell then you're on the same page.
Can't sleep so thought I'd post (will post pic some point today) about a project I've been working on. I pretty much expect some 'flaming' about this but I think I'm well prepared for it.
My air system on my truck has been a pain. From hissing lines to that infernal buzzer, to rusted air tank, and air pack woes...pushed me to looking for something...something better (flame on) or at least less headache.
I initially looked into the hydroboost set that has been used and adapted to about everything. Built an entire system, got it up and running but wasn't happy with the results. Found out a LOT of technical stuff about it and how to 'make' it work but in doing so would be pushing the design of that system to running at about 95% all the time. That's too much...especially when this ain't a racecar and it the brakes of a big dumb truck.
A gentleman named Paul at Hydratech mentioned the Hydro-Max system but said they didn't do much with it BUT, it was a substantially heavier duty unit and was designed for larger trucks. I took that and ran with it.
The hydroboost systems use hydraulic pressure from the power steering pump to assist the brakes in the same way a vacuum booster does. The system feeds the booster then feeds down to the PS box.
The hydroboost system has roughly a 7:1 multipication ratio and an 1-5/16" bore power piston that pushes the piston in the master cylinder. The Hydro-Max uses a much, much larger bore (must be 3" or more) and has around a 21:1 multiplication from what I've found. Hydro-Max is also rated up to 43,000# GVW and is found in all kinds of medium duty trucks from Ford 600, 700, 7000, etc to International S1700's and that monster pick-up looking thing...to name a few.
So anyway, I pulled ALL the air crap off my truck and started over. Like I said the first go was Hydroboost that didn't quite cut it. Second shot was the big hulking brother, Hydro-Max. I picked it up off of an Internation S1700. Master cylinder uses a 50.80mm bore (2"). I had already set up my CAT with a new PS pump from a '93 1 ton Chevy. I got looking around at the big truck lot and found several other Hydro-Max systems. One on a Ford medium duty had a saginaw pump very similiar to mine. I grabbed a high pressure line from that and LUCKILY got to thinking about the the output of the pump and pulled the guts out of the output fitting that controls the volume and pressure out of the pump.
I pulled those parts out of my Chevy Saginaw pump and visable they were identical. Looking more closely and comparing hole sizes with a drill index I found that the Ford pump was outfitted factory with higher pressure and more flow out of the pump by several drill sizes larger. I put Ford Saginaw application stuff into my Chevy application pump to boost it's performance and try to maintain as closely as I could a matched system.
Tonight was my first test and WOW was I happy with the results. When backing up and nailing the brakes it feels like the front completely unloads and you stop NOW. A couple of frozen driveway tests has it pretty easily locking up all three axles and sliding to a stop...which is nice for an 18,000# truck.
Bjorn and his helpful quest for deuce truck knowledge at one point put a pressure gauge on the brake system and posted his findings, iirc, to be 1800psi line pressure locking the brakes. Hydro-Max is supposed to put in excess of 2100psi. This system also has a back-up electric motor pump (in place of a nitrogen charged accumulator like the H-boost) that will give you brake pressure when the engine isn't running. I'll post pics later today when I'm back at my computer.
