- 3,222
- 392
- 83
- Tonopah, AZ
I have completed the AC install in my M936. I used a Hummwv kit but I did not use the Hummwv Condenser, I used a condenser built for the M939's.
The big problem was I could not figure out how to get the motor fan to work with the AC system when it needs it and also have it used by the truck when it needs it.
I figured that out and I also added a manual switch so I can turn on the motor fan anytime. Also added a AC clutch fan switch so I can use the Evaporator fan and not have the AC running.
Removed the batteries and put them in a relocation kit I have had. Painted the area and the air tanks due to having them off and they needed a little paint.
