Hey,
I did my homework and am really looking for suggestions on what path to take from people who have had similar/same issue.
Volt meter shows in top of yellow range
Batteries individually measure 12.6+
Battery voltage across the whole bank = 25.6
I hear the safety relay disengage when disconnecting it from the box
Battery voltage at wire 566 with battery switch on = 25.6
Battery at wire 568 disconnected = 25.6
Engine cranks/starts fine, volt meter shows in yellow range and measures a little lower = 25.3
I removed the regulator back off of the alternator while the alternator was still on the truck. The potting material doesn't look burned/bubbled/damaged. There was no smell, just some dust from the brushes.
Should I be replacing the whole alternator per TM or regulator. My gut says whole alternator. I would probably go Delco 21s. It looks like you just need these items:
http://www.amazon.com/ALTERNATOR-19...+SERIES+1991-1992+3675174RX+10459026+10461235
http://store.alternatorparts.com/partno241507.aspx
and 1/2" of some pipe as a spacer to make it fit, anyone know what diamter the pipe is?
