trider
- 1
- 0
- Seminole, OK
I have some 365 XZL's that I removed the run flats in to mount on Long Wheel one piece rims. I have cleaned the run flat lube/black tar stuff out the best I can but as everyone knows you can not get it all out. There is still some smeared around inside the tire. I am wanting to put balancing beads or bbs inside for safe measure to be sure they are balanced. I am afraid the beads may stick in the tar/lube throwing the tire off balancing and the only way to fix it if this happened would be the break the tire down and clean them out. Does anyone know a better way to clean this crap out? If not should I use balancing beads or not worry about them?
