Keith_J
- 1,316
- Schertz TX
I have not done too much to mine, other than take the air compressor off the floor and mounted it above the generator to save floor space. Made it from 1" square tube, it required no new holes to mount. I still have space for a horizontal cylinder rack for shielding gas.
I have a Dynasty 200 welder in the truck, this is a SMAW and GTAW machine which runs fine on 208 three phase. I still need to change the 45 amp three phase outlet to the twist lock type I have on the welder.
future plans are for a reconnection box between the generator and panel so it can be reconnected to output 120/240 single phase using a low zig zag arrangement. This way it can be used for home backup as well as three phase stock, just not at the same time.
I have also fabricated a class IV receiver hitch and installed an electric brake controller. In addition to the 24 volt DC powered air conditioner, rear view camera and 12 volt power outlet.
