LDS427 Multifuel
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Well, a member here had an LDS427 for sale. The price was right for parts so I grabbed it. It is siezed and missing parts, but there is still good stuff to be had. One of the best things is the manual starter! I hate arcing a screw driver across the solenoid terminals to turn a motor over, now I don't have to worry about it! Also, I noticed the water pump is different. It has the water "J" pipe bolted to it, rather than sliding a hose on like the LDT. It also has the old 25amp generator on it, I guess I'll have to figure out how to test this thing now. Anyhoo, here is a couple pics for everyone to see.LDS427 starter.jpgLDS427 water pipe.jpg
gimpyrobb
27,786
755
Cincy Ohio
I do too. It will be the one that stays with the motor test stand(bottom half of a multifuel can) I have.
Now I have to dig out the 25amp regulator I have stashed somewhere to see if they all work.
swbradley1
Modertator
1,759
Dayton, OH
Wait, you mean I have a manual starter sitting in my vise on my work bench?
I should have walked out there last night. :)
doghead
4 Star General /Moderator
1,179
Mechanical engaged Bendix, not electronically engaged.
Like old cars used to use.
I've labeled the picture.
gimpyrobb
27,786
755
Cincy Ohio
Ray, when that lever is moved, the lever pushes the starter drive assembly forward to engage the flywheel, at the same time it closes the contact for the electric to spin the starter.
Maybe I shouls see if SWB can post a video when I get up there later.
doghead
1,179
See if you can get him to clean off the workbench too.
NDT
6,534
Camp Wood/LC, TX
An old salt once told me the reason the military retained the manual bendix even when solenoid versions were available is that in extreme cold, when cranking amps are critical, the manual starter uses less energy and could get a marginally charged truck running, while a solenoid starter would just chatter. Any truth to this?
doghead
1,179
That makes sense, but I suspect technology of the time was also as much a factor in design.
