Tinman84
- 0
- 0
- Pendleton, OR
Update: SUCCESS!!! Found out that legit end mills are a bit pricey, tried left hand drill bits, cussed a bit, prayed a bit, found out that Dremel makes a bit that is cylindrical and has cutting flutes in the blunt tip and in the sides, and used it to get the busted bolt out.
In the end I boogered up the hole a bit, but not so much that the bolt wouldn't thread and it tightened snugly with a standard ratchet. Since I had the starter out I went ahead and replaced my farmer-fix (affectionate term where I come from) of thread stock with actual through bolts. My parts house accidentally got two that had the support extension on the end, but I went ahead and put them both in anyway. I figure if I ever get in a pinch and the one that's doing the work shears off like the last one, I can just switch them places.
The old beast behaved long enough to let me have a week's break from tinkering, and then help the bro-in-law fix his 4x4 controler on his '94 Chevy pickup, but now it's making noises and I think the transmission may be to blame. Makes sounds like a grating noise, louder near the transmission, rises and falls with the RPMs, and gets much worse when shifted into any gear. I'm thinking it could be the torque converter, but I don't really know. Just started doing it about an hour ago, went from no noise to quite the racket, and I just need to forget about it and get some sleep. If anyone sees this and knows of a specific thread that could be useful, I'd be appreciative of a link, otherwise I'll try to do some searching on here tomorrow before work. Night y'all.
