cucvrus
- 10,265
- Jonestown Pennsylvania
When you get the opportunity crawl under the M1010 and disconnect the transfer case linkage from the shifter. See if the shifter lever going to the transfer case can be moved all the way back. It will help to block the wheels and shift the truck transmission to neutral with the engine off. Because that shifter inside the cab has a gate pattern that the shifter rod must travel in. It is worth a try. I have several transfer cases for parts also. The internal parts are about worthless to me at this point. But some of the parts inside are costly. If you pay shipping I will send you any of the internal parts you may need. I am sure we could trade something. The only thing I ever use are the case parts. They get cracked and broken during snow plowing and off road use.
