drpyloo
- 0
- 6
- Conyers, Ga
Hey folks, I have a few questions about the Behr paint process and adhesion that I hope you all can help me with. However, I will provide some background info first.
Over the winter, I started a project on my Jeep Cherokee (I know it's not an MV, but I wanted my XJ to match my Deuce; and from all I read, I wanted a really heavy duty paint for the off roading I will be doing with it). I sanded the car down and prepped it for paint just as if I was going to do a regular base/clear; with the exception, I did not primer the car.
I read wsucougarx's thread and just about memorized it, so I would have no error. I used the Behr Premium Exterior flat with the 384th code.
After prepping, I gave it 4 light coats with one of the cheap HF guns. I kind of had no choice, but to wait about a day or two between coats because of my work schedule and time constraints. But, I figured the time between the coats wouldn't hurt the curing process. Jumping ahead, I finally finished all of my painting, after about 4 months; of which the car was in my garage the entire time. Of course, I would bring the car outside to get sun whenever I was working on it and figured 4 months would have been more than enough time for curing.
Call me paranoid, but after all of this time I don't feel the paint has either cured correctly or adhered to the surface. When removing the tape some of the paint peeled off the body a little too easily and I noticed the paint seemed "soft". I've also run my nail through the paint and it also scratches too easily. Also, when I rub the paint with my hands it almost seems to develop somewhat of a white haze.
I finally brought the car out of the garage and I have started letting it sit outside. We've been having heavy rains here in GA. Today when I came home from work, I noticed a couple of small sections where the paint seems to be bubbling, almost like water bubbles.
Finally, for the questions.
How hard should the paint be when totally cured?
Should I have used any type of primer on the body? If so, is there any thing I could do to save all of the hours of work I've invested?
I'm beginning to think maybe I should have used the Behr Premium/Primer instead of just the regular exterior?
Is there any type of sealer I could use to better dry or harden the paint? Or, make the paint tougher, or as tough as the CARC on the deuce?
Any tips, suggestions or remarks on what I did right/wrong are welcome since this is my first run at this. My next project was/is going to be the deuce; but at this point I'm kind of skeptical of painting the deuce with this type of paint.
My apologies for the long post, but I want to be as detailed as possible for you folks. I tried uploading photos of the process, but I seem to be having technical difficulties.
