Jeepsinker
- 452
- 83
- Dry Creek, Louisiana
It doesn't limit much at all, it is really there to avoid axle to frame contact damage.
No kidding Garret (jeepsinker) ! 10psi is nothing ! When you consider 30psi to 40psi is normal idle pressure ! That poor "Hydraulic Head" was getting no lubrication !Surprised the truck moved at all with 10 psi of fuel supply. I wouldn't run it anymore until you get the high pressure boost pump fixed. You will destroy the HH for sure that way.
I have never been a fan of rubber dogbones either. All the modern suspensions have them though. Of course none of them articulate as much as a deuce does . If I had enough money I'd replace them all with the new style ones "Eriks" sells. At $90.00 each though I would have to win the Lottery before I could buy them ! To bad no one makes one like the Germans had in there MAN busses. They called it the "million mile" bushing. It was over 8" across and allowed articulation of the "trailer" end of the 60ft buss. I never saw one ever replaced in all my years at the transit agency. It was rubber with a bronze bushing . I believe the bronze bushing rode on the shaft (about 2" diameter) and the rubber surrounding the bushing allowed twisting motions up to 30 degrees left or right. If I had a machine shop I would see if I could come up with a dogbone bushing that was made of "bronze" and rode on the pin and was surrounded with "polyethylene" to allow twisting. With a greasable fitting I believe such a creation would last a lifetime !You like torchin up deuces, don't ya?
This one is stayin' together at least as an engine test cradle for the time being.
If there's one thing I really don't like about deuces, it's dogbones. If I'm gonna pay money to buy new ends and change them all out, I'd just as soon buy the good ball and socket ends, but they aren't cheap when you gotta buy 12. I'm afraid rubber won't last very long in this desert...then again, some of the ones on this truck don't even have cracks in the rubber. Need to prybar test them.
Which, reminds me...an old milsurp guy that used to supply parts to all the farmers, etc. that used to run milsurp trucks around here told me that if you drop your bumpstops 3" with metal block/spacers, the dogbones don't get stressed as much and last longer.
YupThat would be cool. No reason the new ones from Erik's shouldn't last a very long time though, especially as little as most people drive their deuces. Just remember to grease them.
\Seat of the pants, 10psi isn't much pressure but it's still flow. I doubt the HH will burn up, unless run super high RPM. It'll probably wear slowly, which it may have already. Anyway, I'll get it fixed.
This truck will probably stay together indefinitely. I hate taking things apart and having crap laying around everywhere that I have to move with a forklift, and having to try to figure out how to seal disassembled things up. The sun here kills anything you might use to seal stuff up. Gotta do something with those spare axles and parts...
Rob, you're right, it is a good project base. I'm already wondering what kind of turbo might be best on it since the intake and exhaust aren't stock anyway. Maybe something newer and more efficient that spools quicker. I might build my stumpy stripped down 6x6 truck idea out of this one...unless you wanna buy it!
rusty, great minds thing alike. I have a machine shop and plans or a rough idea of how to turn my dogbone ends into "johnny joints".
http://www.currieenterprises.com/cestore/johnnyjoints.aspx
I replaced all 12 of mine with the rubber ball joints, and WOW what a difference! I've since taken my Deuce off-road on some washed-out, rocky desert trails, and the articulation has to be felt to be believed...not to mention it didn't have near the jolt while rock-crawling like my 4x4 trucks do. The articulation is quite impressive. Erik's new metal ball-and-socket joints came out after I replaced all 12 of mine, naturally, but those seem to be the perfect ticket for your climate.If there's one thing I really don't like about deuces, it's dogbones. If I'm gonna pay money to buy new ends and change them all out, I'd just as soon buy the good ball and socket ends, but they aren't cheap when you gotta buy 12. I'm afraid rubber won't last very long in this desert...then again, some of the ones on this truck don't even have cracks in the rubber. Need to prybar test them.
