- 3,256
- 3,354
- NORTH (Canada)
So the machine shop has my heads and they panic a little (I thought they did plenty of trucks and tractors, but maybe not). First, they were concerned about cracks. I supplied the pertinent info out of the LDS troubleshooting manual (cracks typically in two locations, between valve seats and around injector port; OK if no penetration into water jacket on pressure test). Now they question whether any material can be removed from the bottom at all, because there is not much there (in comparison to a small block Ford I guess).
My information is that 0.002 inches (2 Thousands) can be removed and that warps of 0.004 or more are the wear limit. I also think that the valves need to be set back the same amount that was removed at the bottom.
Can anyone confirm this or point to a source with this information?
