Official 2015 Ga. Rally buy/sell/trade thread
MWMULES
345
DESOTO, KANSAS
I have one like new 6 step aluminum with hand rail wide boarding ladder.
May have some others by rally time.
I have never heard from anyone on the HMMWV tow missile racks so will stay home unless I get a PM.
Same on the Litter carriers
wheelspinner
1,518
North Carolina - FINALLY !
DECONTAMINATING APPARATUS: POWER-DRIVEN, PORTABLE $150
It is basically a fuel-fired water heater with pressurized delivery. The water pressure and temperature are adjustable. From briefly reading the manual, it appears that the highest pressure setting is 100 psi. As with any military equipment, it is heavy duty throughout. It weighs about 360 lbs.
It has a two-cycle gas engine that powers the pump and fan. The motor does turn with the pull rope. The water heater is multi-fuel fired.
The base unit appears to be complete. There is a vinyl cover included (not shown ).
There are no accessories (hoses, wands, nozzles, etc.)
Here is the complete TM:
View attachment TM-3-4230-218-12-and-P.pdf
I got this on trade and I haven't had a chance to really go through it. The engine does fire if primed at the carb, but I have not hooked up a fuel tank yet. I did purchase a new water pump belt which was absent.
I am not attending the rally, but have made arrangements with the one and only gimpyrobb to deliver to the rally. Would consider prearranged trades for deuce stuff.
SCSG-G4
PSVB 3003
3,272
Lexington, South Carolina
Found yet another towbar to bring. It's NOT a medium! About five feet long, not adjustable, holes for the pins to connect the feet are a measured 1.660 inches in diameter, so the correct pins would be 1 5/8" dia. Weighs 110-115 pounds. $100 or best reasonable offer.
Had a troop that has been a tanker look at it yesterday. He said it looks just like the ones found on M113 and M114 attached to the front and leaned back on the slope of the armor. So those with that type of tracked vehicle could be possible buyers.
wheelspinner
1,518
I want to update what I will have:
About 10 Good tested pairs of these Route Lights $100 per pair. First come first served, one pair is paid for already: I set it on the bumper of my Deuce for scale- THEY ARE BRIGHT!
I will also have 5 pairs that when tested were a little yellow, still bright but not nice and white-Those will be $75 a pair, perfect for spots, backups whatever
I have (4) - Two pair of Large bar feet with 1" pins, which are included. These are NOS and I need to get $175 a pair
I have two HMMWV Hood Grilles, One ARMORED and one standard:I need to get $175 for the armored style and $150 for the standard. These are very nice condition for those who were lucky enough to get a HMMWV already and need a nicer one.
Recovry4x4
LLM/Member 785
1,806
GA Mountains
Folks, if anyone has parts CUCVs around I am looking for the buss bars behind the rear battery. I'd rather have the shorter ground one but I have to go home and double check that it's insulated from ground, I need it for power.
Al Harvey
19
Dover, TN
Recovry, I got both buss bars I just took off a parts truck. I'll make a note to throw them in the truck and then you can take whichever one will work. I'll have to look and see, but I think I have the covers too.
73m819
319
gainesville, ga.
Quote Originally Posted by 73m819 View Post
SWISS and 73m819 want and committed list
SWISS -- Need an 800 series steering column. Found one
SWISS -- Trade or Buy Looking for 11 G177 tires, can trade 7 good 14x20's, 3 are new.
73m819 -- I am looking for 4 of the cab outside grab hand holds, these are mounted on the tub just before or right at the rear corner curve of the tub,. found some
Rmtaunton -- Snatch block for 5 ton, We have MORE then 1, talk to swiss
]swiss -- Joe put swiss down for a set please (pole set)
73m819 -- Put 73m819 down for a set, thanks (pole set)
73m819 -- Looking to buy or trade for TWO clear lenses for the single light armored head lights. Will swap a pair of ir lenses for clear if someone is looking for the ir lenses.
73m819 -- Sorta looking for TWO 939 a0/a1 fuel tanks NOT a2 or tractor, or the small wrecker tank.
73m819 -- Someone buys this truck, talk to me about driving it to where it needs to go.(Sandcobras truck)
73m819 -- will take 3 81mm brown
swiss -- Another 81 brown please And 2 60
swiss -- Looking for some Jameson Florescent lights not at e-bay pricing. PM me if you have some to sell. (do not know if this has been found ???)
73m819 -- Twight, I have 3 specter fuel cans at you place (i think) that I brought from Carnac, could you PLEASE bring them to the rally, thank you. (dealt with)Thank You
73m819 -- I WILL take it (939 air drier) if joe does not. ALSO looking for a 939 foot brake treadle valve
Andyrv6av8r -- I think I have 2 driers Ron.
sandcobra164 -- Ron, I have a M939 series treadle valve with pedal, new never used. I'll confirm tomorrow, gotta dig through my parts bin.
73m819 -- I sure would like 4 PSP sections
73m819 -- Adam, I could use a metal air gauge, NOT one of those crap plastic ones.
73m819 -- looking for A 809 series front winch drive shaft.
73m819 -- looking for 200' of 5/8" NEW winch cable
73m819 -- Looking for 2 or 3 G177x20s, on or off rim
73m819 -- Looking for a METAL water temp. gauge and sending unit as a set
73m819 -- I will take a glad hand bunch, need at least two with glad hands.
73m819 -- need ONE fuel gauge selector switch with lever, a NEW need has made it self known
73m819 -- Need TWO military on/off switches with lever,
73m819 -- Need TWO 809/939 start switch with lever,
73m819 -- Need FOUR extra levers for the military switches
I think this is ALL, I hope, as it is NOW, I am going to need to acquirer a BIG trailer just to haul ALL our acquired goodies back to the AO and the FOB.
Have a SS member that will not be at the rally, he is looking for,
A level wind for the front 5t wench,
A tractor behind the cab gear box,
TWO GOOD 1400rx20s on the two piece 5t rims
timntrucks
116
Ponchatoula LA
i still have the tool box for a tractor, 2 cases of mres left, the severe weather sleeping bag, turn signal, and the front part of the weather cover for a duece or 5 ton 800 series and a couple of mbu burners v3 type
pctrans
19
Bradenton, FL
Part of my "house-cleaning" parts list: (for items not priced, I will accept reasonable offers)
M-816 "wiffle tree" with pins
Metal Jerry can
NEW tan Jerry cans - $60/ea
NEW 24-volt Impact wrench w/bag - $300
Bridge plate sets - $10
Slave cable adaptors (2)
Tan M105 cover
12-volt Red Candy Bar Light - $50
Slave Cable Set - $250
Deuce air tank sets (3) - $40/ea
NOS Air Tanks (9" x 37") - $25/ea
Fiberglas uprights w/corners (35) - $15/ea
Wood uprights w/corners (13) - $10/ea
Tan fiberglas uprights (10) - $5/ea
Green fiberglas uprights (8) - $5/ea
Tan extra-tall uprights w/corners (20) - $200/set
Tan metal bows (10) - $15/ea
Green metal bows (6) - $15/ea
Green wooden bows (6) - $10/ea
Longbed cargo cover, camo, 900 series - $350
Pair of 900 series mirror brackets - $25
Deuce radiator, unknown condition - $200
2- Deuce radiators, flushed/tested - $400/ea
Deuce fan blade
Cummins fan blade
800 series muffler, used but solid - $50
NOS Deuce pressure plates - $30/ea
Deuce bumperettes - $30/set
Deuce driver-side tool boxes w/steps (2) - $25/ea
M101 side rail set, tan NOS - $125
M101/105 metal bow set - $125
Deuce/5-ton rear window panel - $50
M105 end rail panels, 3 tan, 4 green - $20/ea
more to follow........
I've got BUKU fiberglas uprights (standard and extra long) w/metal corners $10/ea with quantity discounts.
Also found a few NOS refueler hoses w/nozzle - $50/ea.
I am liquidating all my A3 Deuce parts, so make an offer on items listed in post #235.
Also found a decent muffler w/guard and tailpipe - $75.
jw4x4
Dayton, Ohio
I may be able to bring some Deuce and a half air compressors if there is interest. They are brand new, dated 2006 with seals. Price is $175. IMG_1141 (1).jpg
