- 2,515
- 2,014
- Efland, NC
As part of checking the damage on the MEP803 I picked up today I noticed something that should be resolved in the generator electrical section. The way the wires are routed from the reconnect switch to the terminals below they cross over some sharp metal edges with no protection. I can see on one wire that there is already some fraying. If that were to continue long term it could lead to a dangerous condition with the generator.
I'm going to put some rubber stripping along the two edges to give the wire something to rub against without causing damage. I'm also going to look at moving the wires around to see if I can get them away from those edges.
