drivebymashing
- 51
- 28
- North Carolina
Im near Asheville NC If you need a hand I thought about driving my deuce 730 miles last week to pick up a m105a2 i drove a 2008 chevy 1500 instead ALOT more confortable.
Glad you made it home safe with no issues.Pictures and videos coming soon. 800 miles in 2 days. Feeling the burn in my shoulders worse than anywhere else. Respect to the guys who drove these things, pulls like an ox, screams like a banshee, and has the suspension of a mule. One thing I noticed was smoke in the fuel tank whenever I pulled off, but it was never hot. I originally thought blowby, but it doesn't smell combusted, is it possible for the fuel in the return line to get warm enough to fog?
DMV today, then more sleep. Maybe a trip to a masseuse. Never thought they were useful before, today though, I might change my mind.
My biggest manual transmission driving experience is when I used to drive the 78-passenger school bus at our church to go around town and pick up kids for Sunday school. That was a while ago, but I didn't ever run over anyone or anything and I've driven sticks almost my entire driving life (since 1980). I've also been reading items here and watching YouTube videos on how to drive and operate an M35A2. Building my list of things to acquire before I pickup the truck. Looking forward to it, but a little apprehensive as well.Glad to know you've got BIG vehicle... manual transmission experience. That's great to hear!
I'm south of Tulsa, about half way between I44 and I40. I drove my deuce 750 miles back from Georgia, and I can tell ya, it's an experience you won't forget!
Thanks for the info. Yep, I'm 90% excited and 10% worried. Not sure if that is the correct ratio, but I can adapt.I'm south of Tulsa, about half way between I44 and I40. I drove my deuce 750 miles back from Georgia, and I can tell ya, it's an experience you won't forget!
How do you like the air-powered wipers? I used to have a 1968 AMC ambassador with vacuum powered wipers, meaning they only worked when you were not accelerating. They ran real fast when slowing the car down & stopped during acceleration. I think the air wipers will be much better.Follow the Instructions of this thread and you will be fine. image dump in next post, and a few better pics when its not freaking raining in Florida. 3 days straight so far with more expected in the morning.
The wipers work pretty good on our deuces as long as you maintain them. The control valve gets filled with crud so they need to be taken apart and cleaned on a yearly basis. I also replaced all my hoses with DOT 1/4" Poly air-tube. No more leaks for me.How do you like the air-powered wipers? I used to have a 1968 AMC ambassador with vacuum powered wipers, meaning they only worked when you were not accelerating. They ran real fast when slowing the car down & stopped during acceleration. I think the air wipers will be much better.
Sounds like a great idea. It rains so little in AZ that the wipers on my Jeep dry rot long before they ever wear out. Still think I'll take your advice and go with the better air tubes. Thanks for the info.The wipers work pretty good on our deuces as long as you maintain them. The control valve gets filled with crud so they need to be taken apart and cleaned on a yearly basis. I also replaced all my hoses with DOT 1/4" Poly air-tube. No more leaks for me.
Hey Rusty, Any opinion on whether or not an air/water separator is a good idea to add to the system? Just to keep the moisture out of the air tanks more. Blow downs would still be a every drive occurrence, but it would help keep the moisture out of the tanks even more.The wipers work pretty good on our deuces as long as you maintain them. The control valve gets filled with crud so they need to be taken apart and cleaned on a yearly basis. I also replaced all my hoses with DOT 1/4" Poly air-tube. No more leaks for me.
I installed a "Bendix" AD9 Air-Dryer last year. I went with the Bendix since parts are readily available and cheaper then any other air-dryer replacement parts on the market. I also installed a 7 gallon stainless steel air tank for my wet tank. My air is nice and dry now !Hey Rusty, Any opinion on whether or not an air/water separator is a good idea to add to the system? Just to keep the moisture out of the air tanks more. Blow downs would still be a every drive occurrence, but it would help keep the moisture out of the tanks even more.
Rusty, I think what I am hearing is the unloader valve. It's only at idle that I hear it, and it's coming from under the hood, not the tanks. The truck is holding a solid 120. When the unloader valve is open the compressor is pumping to atmosphere right? When the sound occurs it's short and cycles every 5 or 10 seconds for about a second. The engine also smooths out a bit when it happens.Whenever it is running at idle and the brakes aren't being used, I can hear air blowing off. The tanks are at 100% so I presume it's because the Compressor doesn't have a modern electronic clutch to turn itself on and off with so it blows off like an old steam boiler used to to prevent an explosion. Is this "Blowoff" normal?
No it's not normal. Your "unloader" valves are probably stuck. They get there pressure signal from the air-governor to open when the air-compressor reaches the shut-off pressure (usually 120 psi) . When they open they are basically venting the air-compressor so it will not build up any air pressure. If they are stuck closed then the compressor is always building pressure which then is released at either the pressure relief valve on the tanks or sometimes the governor.
