coachgeo
- 3,404
- North of Cincy OH
Essential Tools & Spares to have for an FMTV? Add your .02
Been searching and reading various threads that mention TOOL.
Not come across a comprehensive thread sooooo... here we go. Please make suggestions on tools ands spares to carry and where to get them by making a post to this thread. Will keep updating the list in this top post with things discussed in post you add below. List has got a few questions added below as well. Will update list according to your suggestions on these questions.
Via idea brought about by 98G..... splitting this top post up. It will start with a a KISS LIST of items (keep it simple and stupid) Following that will be the complex list with more details if one wants to read further.
KISS LIST
list of tools actually used in 40,000 miles of various recoveries of FMTV and other MV's
TM tool list pdf for FMTV's
List with more detail
ps- This is NOT "my list" It is a list created by users here. THANK YOU to everyone that has contributed.
TOOLS
T=Tool. W=Where. MCW=a Must Carry With item on excursions. Excursion being 100 or more miles and involves offroading that requires CTIS activation to navigate terrain efficiently.
T. Technical Manuals (TMs)
W. This Board
MCW. YES
T. Lug Nut Removal kit. 38mm/1" drive socket and corresponding breaker bar,
W. Various
MCW. YES
NOTE: as suggested by Oxyacetylene if you are going to purchase some 1" drive impact sockets, take a look at Harbor Freight. The metric set comes with a 38mm deep well for lug nuts. Sign up for their coupons and use a 20 or 25% off coupon to purchase. http://www.harborfreight.com/10-pc-1-in-drive-metric-impact-socket-set-67987.htm
T. Impact Wrench and Air Rachet. Air type with whatever is needed to hook her up and/or 24v type and wires to NATO that Im guessing is what was standard use with these. Best air or 24V? my vote air..... see Pass thru socket info further down
W. 24v can be got on this board probably ebay too. Air anywhere. with hose adjustable air regulator and Gladhand attachment orrr?
MCW. Yes or no????
T. Sockets for Impact..... what sizes most common have ya'lldiscovered is needed? Pass Thru Sockets and adapters are available for some types of Impact. See below
W. H.Freight? Sears?
MCW. ???
T. Ratchet and Socket Set. what sizes most common have ya'll discovered is needed? FWIW I like PASS THRU sockets myself but rachet's head is larger and not as good in tight spots?? Can now be used with Air Rachet wrench as well see http://www.vehicleservicepros.com/a...oduct-tool-review-december-2014-pten-magazine
W. Amazon, Hardware Store, Ebay Etc.
MCW. Yes
T. Breaker Bar That fits your ratchets and other tools..
W. Various
MCW Yes
T. Allan head Sockets Most of the FMTV is metric. For sure a metric Allen head socket to remove the fan in case you have to change your water pump belt.
W. Various
MCW Yes
T. Open End wrenches. what sizes most common have ya'll discovered is needed? Most of the FMTV is metric.
W. numerous
MCW. yes
NOTE- SAE - Metric equivalents one might can use in a pinch http://www.steelsoldiers.com/showth...-Add-your-02&p=1857395&viewfull=1#post1857395
T. Drive Shaft remove tools (for towing, repair etc.)
MCW. Yes
T. Towing supplies (any of the various Military Tow Bar arrangements that will fit) and wiring for tow lights
W. This site, Military Surplus places, Ebay
MCW. Yes
T.Multil Meter
W. Various
MCW YES
T. Grease Gun
W. Various
MCW. NO, then again for LONG excursions there is small ones you should throw one in
T. 20ton Bottle Jack with soft ground platform, and other cribbing blocks. (several 4x4's so you can stack them)
W. Various
MCW. YES
T. Wheel Chocks
W. Harbor Freight, Military Surplus etc.
MCW. Yes
T. Highway Break Down Safety items- Warning triangles and High-vis vest, flares, smoke, claymore, thermite grenade..
W. Various
MCW Yes
T. Jumper Cables , two so you can jump from one or two 12v vehicles. NATO jump cable so you can jump from other military rig. Maybe pig tail from NAto to one or two 12v vehicles?
W. ???
MCW. YES
T. RECOVERY Items: A super heavy snatch (recovery) strap or rope*. Winch/Come-A-Long orrr? Tree saver, Clevis pins etc. for attaching, SNATCH BLOCK or two or three. Don't forget to lay jacket orrr?? on any cable in tension in case it breaks to prevent it from snatching back and thru windshield thru your head(widow maker) or thru nearby persons Head (you've now killed someone!!!) NOT A JOKE.
W. 4x4 Shops, Amazon, Ebay etc. *Video of one from member here.
MCW. YES YES YES
T. Tie down/Away supplies Rachet straps, Rope, Bungie Cords (at least to keep the 350lb tire from falling over during a tire change or removal, or to hold in place then easily lower/raise a driveshaft when being removed/installed)
W. Various
MCW. YES
T. Heavy Duty Duct tape
W. Pluck a Duck
MCW YES
T. relay bypass- 2 spade crimp terminals on a 6 or so inch wire. Photo's at bottom of page
W. Auto parts store, Walmart etc.
MCW. YES
SPARES
S=Spare Item, W=Where to get, MCW= Must Carry With on Excursions.
S. Electrical- Fuses, relays, circuit breakers. 12v bulbs (if yours is not LED converted)
W. Numerous
MCW. YES
S. Tire(s)
W. numerous. What size is on LMTV generally?
MCW. Yes, LONG Excursion then maybe two
S. Zerk Fittings (any particular size, or type?)
W. Numerous
MCW. NO for short Excursions. YES for LONG Excursions.
S. Ujoints
W. Friendly FMTV dealers on this board
MCW. YES
S. Assortment of standard blade-style automotive fuses might be worthwhile. They fit in the slots where the breakers go.
W. Generic Auto parts place
MCW.. so so. Not so much so if you have jumper tool as mentioned above???
S. Relays, you can swap a relay from a less-critical spot sometimes. Example swap bad marker lamps relay with the blackout drive relay.
OTHER
O. Make sure your brake chambers have the cage T handles....mine were all missing.
W. NA
MCW. YES
O. AAA PLUS RV Towing/Service membership or similar. Who do yall recommend is is AAA still the best for this?
W. Online search
MCW. YES
O. LOT OF CASH or Large Limit Credit card and/or tools to Rob a Bank, knock down an ATM etc.
W. Local Bank?
MCW. YES
KISS LIST
Jacks X2 + cribbing
Impact wrenches
1.5" sockets
3/4" sockets
1/2" and 9/16" wrenches
Oil
Water
Glad hand air hose with air chuck
Chain
Fuel can
Fuel line
BFH
Batteries
Slave cables
Battery charger
Crowbar
Wd40
Your FMTV tool kit contents.
Just curious as to what you carry on the truck every day. This is also a thought exercise because you might have something in your kit that someone else never thought of. My list: Basics: 1/4 to 1/2 shallow and deep sockets with extensions and u-joints Ratchets for above and a long 1/2"...
TOOLS
W. This Board
MCW. YES
W. Various
MCW. YES
MCW. Yes or no????
MCW. ???
MCW. Yes
W. Various
MCW Yes
W. Various
MCW Yes
W. numerous
MCW. yes
- 8mm (5/16" in a pinch) deep well socket or maybe a Pass-thru socket (haven't tested for fit in this area) specifically to pull the grease zerks from the U-joints prior to removal. If you don't you'll break them off.
- OTC 5190A U-joint puller for driveshafts. http://www.steelsoldiers.com/attachment.php?attachmentid=614980&d=1459169891
MCW. Yes
MCW. Yes
T.Multil Meter
W. Various
MCW YES
T. Grease Gun
W. Various
W. Various
MCW. YES
T. Wheel Chocks
MCW. Yes
W. Various
MCW Yes
W. ???
MCW. YES
MCW. YES YES YES
W. Various
MCW. YES
W. Pluck a Duck
MCW YES
MCW. YES
SPARES
W. Numerous
MCW. YES
S. Tire(s)
W. Numerous
S. Ujoints
MCW. YES
OTHER
W. NA
MCW. YES
W. Online search
MCW. YES
W. Local Bank?
MCW. YES
