dk8019
- 55
- 28
- Lovettsville, VA
Warhorse, I would consider it, but I don't think I grasp the advantage of the higher current setup. I understood the 200A setup was the handle heavier electrical loads, correct? I can't see my 998 every drawing more than the headlights.
$350.00 to $400.00Warhorse, very interesting! Any idea on the total cost for the setup?
If the aluminum bracket can fit the new 200amp. Can I not replace it? If I reinforce it with an improvised piece of twisted metal--like one in the back--to the front part where the bolt attached?
is the new bracket all about stronger steel material but not fitment? My measurement is that the 200amp gen will fit the old aluminum bracket perfectly fine.
thank you
