WRECKER AIR VALVE 936a2
infidel got me
32
Newberry, Florida
I have looked for a few hours trying to find this and came up empty handed. There is a valve after the cab that is called a pto control linkage valve? The truck is a 936a2 and I have checked all the vendors and have not found it. Is there another name for it? It throttles up the truck and locks the brake from what I have read. There is a leak /crack at one end of it and dumping air bigtime. Any help will be appreciated.
Suprman
685
Stratford/Connecticut
I think thats a later mod. My M936A2 does not have that I have to manually throttle up. There are other threads discussing the auto throttle up feature though. Sorry cant be more help.
Will
infidel got me
32
Newberry, Florida
Its on a friends truck and I'm going on what he's telling me, so you are probably correct. My main concern is to stop the air leak but the locking of the brakes (while the pto is engaged is another concern) I do thank you for the reply.
M35A2-AZ
390
Tonopah, AZ
My M936 has that also, all of the A2's that I have seen did not have it. Sorry not much help with your problem.
infidel got me
32
Newberry, Florida
M35,
I am going to say that that is it. Do you have a name for that sucker and where I could get one? I looked for a long while with a lot of vendors and came up empty.
Swamp Donkey
The Engineer
119
Gray, GA
I think this is what you're looking for. Oshkosh Equipment has them.
NSN: 4820-00-808-6905
P/N: SP2346CM or 11640318
infidel got me
32
Newberry, Florida
Just for the record this valve is called POWER DIVIDER AIR VALVE and is used on m816 and m936 series wreckers. Cost is under $40 on a popular credit card maxing out site. THANKS AGAIN GUYS
Scar59
41
Mt. Eden, KY
Subsribed; I think that valve is deactivated on my wrecker, got to go check the configuration.
JC
Swamp Donkey
The Engineer
119
Gray, GA
He said that's the one! Thanks a boatload ---I owe you a cold one or twelve.
Ain't no thing man. Having dealt with so many of these parts as the other side of this hobby, I've basically got the -24P TMs memorized now. Just a matter of remembering where it is. The picture solved the puzzle. :mrgreen:
For future reference, the valve is referenced in TM -24P-1 / Work Package 183-2.
