- 894
- 1,734
- 93
- Wauchula, FL
Using the civilian Truck-lite LED Headlight. It also allows for any other civilian headlight to work.
Modified an H-4 harness by soldering some military connectors onto it.
First heat the connector and fill with solder.
Then while the solder is still fluid insert stripped wire into connector until its solidified.
Don't forget to put the rubber boots on before you solder it.
If you can't read the label... 17 top left is High Beam, 18 is top right low beam and 91 is the bottom Ground.
Lights on High Beam and no Flickering without using the anti flicker modules.
