- 4,173
- 3,054
- Near Austin, Texas
My M813 and deuce. Gives a good idea of relative size.
Cheers
Cheers
No internal combustion engine will tolerate a 3 min drive very long. Moisture build up and batteries not fully recovering the start cycle are just a few of the issues that will lead to maintenance issues. Add that this short drive will be in real cold weather and more issues will surface.How do these do with shorter drives? (i.e a 3-minute drive to the transit center, then taking the bus to avoid campus parking and rush hour traffic?)
Can you elaborate on the install of the block heater. I thought about purchasing one for the winter but havent gotten to it yet. I thought the install was a little involved with removing a cover on the block and there would be coolant loss.as far as block heaters go, I picked mine up a Napa for around $60. install was a snap. Starts like summertime even a 0 degrees. If you plan on using it year round in Alaska just remember all of your other fluids are going to be the same temp as the ambient air is. Bill
The 250 wont even warm up with a 3 minute drive. Especially in colder climates. I run mine a few minutes to warm up and settle down then off we go. Then its pedal to the floor. The older trucks need to be run. They were not designed to be a real daily driver. The coolant temp needs to come up and the thermostat needs to cycle a few times. Then you can load it up and let her eat it.How do these do with shorter drives? (i.e a 3-minute drive to the transit center, then taking the bus to avoid campus parking and rush hour traffic?)
Zero-Start make a nice heater for the 855 block. Very easy install, yes, coolant will need to be drained. Strain it and put it back in.Can you elaborate on the install of the block heater. I thought about purchasing one for the winter but havent gotten to it yet. I thought the install was a little involved with removing a cover on the block and there would be coolant loss.
Have you driven one yet (5 ton 809 series or 939, 2 1/2 ton)? I know Alaska... but your driving (street, freeway, city) is not what these trucks are designed for. Have you checked into insurance when used for a daily driver? I've bought 14 and sold 10. so have had both 5 tons of different models and recently (2) A3 deuces. I wouldn't want to have to rely on either, day in and day out.Good to know these don't like brief drives! 30-ish minute drives should cut it though right? I'm talking some residential streets possibly, then 55MPH hammer down on the freeway for a few miles, then some city driving, then that's it.
No, only relatives lived there and not right now either.TobyS, have you spent a lot of time in Alaska then? It's crazy how many people are connected to AK. My roommate here and I actually met because of Steel Soldiers. (look at my forum threads, the story is in there, you'd get a kick out of it). I haven't gotten far enough as to get insurance quotes, since it'll probably be another year or two before I get one...I'll get quotes then. I haven't yet actually driven one, but I've sat in the driver's seat of an M939 and have ridden shotgun in a Deuce and have tried pop starting a Deuce by being towed by a material handler if that counts as driving one! I will hopefully be climbing around on some M939s this winter and may get to drive my roommate's M923A1 in a year or so, they've offered to let me drive it. I'm excited to drive one.
