Paycheck
- 0
- 0
- Buckeye,AZ
Have minor blow by is this anything to worry about or should I look into rebuilding the 6.2 thanks
He waited 1 hour for a instant answer to the other before posting the same question in another froum.
Didn't see my posting so I redid it !He waited 1 hour for a instant answer to the other before posting the same question in another froum.
Yea
He already sent me a PM calling me names.
In the time he's spent on all this he could have found out the answer.
.......and to 20 more questions.
What's a CD-R valve ?CDR valve clean?
Sure sign of a clogged CDR valve.Light mist coming out at oil fill tube thank you so much for the advice
It's in the shop getting transmission and transfer case rebuilt previous owner abused it I know it mists at full tube on idleOne quick question. Is the oil vapor/mist only present at idle? If so that is pretty much the norm. If you have the oil cap off at idle and you just step up the idle a bit. The norm is it the vapor/mist/smoke goes away. Check that out and see if it holds true. I know when I change oil I can smell the clean oil vapors coming from the breather cap. Good Luck. Report back.
