So, fuel experts out there, here is the order of operations so far on 250+ gallons of free fuel oil off of craigslist (10+ years old),
-pumped (unfliltered) out of original tank leaving the bottom 5-10 gallons of sludge/water(?) (opened the petcock until dark fuel oil was coming out before pumping) into transfer tank
-pumped out of transfer tank with water block/filter into 250 gal storage tank
if I then pump out of the storage tank with a clean, fresh filter/water separator into the truck (or jerry can) and treat with Pri-D ( http://priproducts.com/ ) and possibly Sea Foam = ok to use?
