therooster2001
44
Colorado
This should be fitting then:
Get in our way, we'll put you on your shelf
Another day, some other way
We're gonna go, but then we'll see you again
Another Ahab
4,556
Alexandria, VA
Looked at the slipped dog bone on my 9, and decided to go to a Ratt concert instead.
Sounds like my teenage years, Work? Nah.
Ratt? Oh heallll yeah!
I missed the band, and don't know the song, but guessing that there's a screaming guitar riff in there somewhere, is there?!
Buffalobwana
178
Frisco Texas
Typical 80's hair band. You didn't miss too much. They were good, but not like Motley Crue, Skid Row, Whitesnake, Bon Jovi, Poison, Cinderella, but more like Winger, White Lion Warrant, or Lita Ford/Ozzy combo, although, I did play the same Warlock BC Rich guitar that Lita Ford played, so I guess she's cool too.
What a trip down memory lane.
WV New Guy
Berkeley Springs WV
New batteries finially and mounted a maintainer too. image.jpgimage.jpgimage.jpgimage.jpg
Also so added new front lenses and locking door handles . Drivers side went n great lower screw on passenger side fell out gonna need a longer screw . Never had a handle on the passenger side before.
Gonna work this week on fabbing tie downs for the batteries using original posts .
Buffalobwana
178
Frisco Texas
Never had a handle on pass side? Need a longer screw?
Hmm. I wonder if there is a problem inside that made the last owner opt out of a passenger side handle. your screw should fit fine. I suspect an internal problem. I did the same swap. All screws are same length. Should fit.
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
Updated my starter with a 35lb lighter gear reduction unit. So now the mighty small cam can sound like the magic schoolbus on startup too. meow! I will say though that on the 250 starter you do have to make your signal wire longer to reach.
Replaced my springs to the wrecker style setup. You have to replace the end saddles since the standard cargo will only allow 2 of the longer leafs to fit. I went ahead and bought new bolts rather than trying to save the old ones especially with carc on them. $115 for 16 grade 8 7/8" x 9" bolts with lock washers and nylon lock nuts. I did not go back with fine thread. And don't give me that debate on which is stronger fine or coarse.
Another observation I noticed is that if you replace the upper torque rods to the "new HD Style you will have to pull the saddle off the axle to get them in. or Pull the dog one bracket totally. That outer lip from the HD style wont let it clear the bump stop that is made to the saddle. THIS IS FOR THE WRECKER STYLE SPRINGS ONLY. Other trucks your bump stops are on the side of the frame.
You can see the crack in the one spring. That is how the set I had break last year started as well.
Another Ahab
4,556
Alexandria, VA
Sounds pricey, but being Grade 8 and breaking it down per bolt (with the loose hardware) that's about $7/ which isn't all that bad. Did you think?
simp5782
9,384
Mason, TN
The replacement fine threads are around 15ea. Thru Memphis equipment they are 22ea. The pain of getting all the paint off the threads is very time costing
Sent from my SM-G935P using Tapatalk
armytruck63
10
Redlands, CA
Traded it for a 1987 GMC C30 crew cab dually. Sorry to see her go, but the wife is happy with my decision.
Edit: that was confusing. The truck went away, not my wife!
Jbulach
2,194
Sunman Indiana
Ooh.. I can see you slipping over to the dark side, the starter IS where it starts! With that big Cat trany you could really crank up a little bus motor.
Looking forward to a ride report!
Do you happen to know your typical weight on the rear tandem empty, with your trailer hitched, as well loaded heavy?
simp5782
9,384
Mason, TN
Empty at 26k with one empty fuel tank. The 71k is with the dolly and lowboy setup with a m932A0 on it. 39,500 with the truck and m322 empty.
simp5782
9,384
Mason, TN
In all honesty. After a little test drive after I did one side with the spring swap. VS with both sides having wrecker springs. It rode better with one side as stock springs and one wrecker spring unloaded and loaded. Weird.
simp5782
9,384
Mason, TN
Wes, you may have missed that one. :)
No. He misread the original post cause most northerners dont understand the southern lingo. As far as fat jokes. Well. Its ok. Ole girl can be fat since she works hard and doesnt sit in the driveway like his Winnebago
