USMC 00-08
- 164
- 63
- Skiatook, OK
I am still trying to solve this issue and prefer to do it once. After jasonjc mentioned having problems with the Napa 14451 cups, it caused me to step back and look some more.
Here are the two seals side by side. The outer lip of the Napa seal is thicker and I can see why this may have caused jasonjc the problem he had and one that I would like to avoid.
Here are the two seals on each of the different kinds of pistons.
I don't know if I should use the new pistons with Napa seals, the old pistons with the seals out of the new wheel cylinders or use the Napa seals on the old pistons in the new wheel cylinders.
I would greatly appreciate any insight here. Especially if anyone knows how to test these before I go through all the trouble of tearing everything down and putting it back together again.
