I have a '91 hmmwv. It has a 200amp generator. I've been noticing the battery gauge is always in the yellow and never switches to the green gen mode. I took the batteries out and charged them individually truck starts and runs fine no issues. I've checked the 28v and 14v post on the generator and there is no voltage so my guess was that I have a bad generator. I bought a tested refurbished 200amp gen and put it in still no voltage output not charging the batteries. I also tried removing the ground cable from the batteries when the truck was running because to my understanding if the generator is working the truck should still run and it did not turned off right away. So I still think it may be the generator maybe the supposed tested refurbished generator was no good or am I missing something is? Would the EESS have something to do with this? To my understanding if the generator is running even if there is other issues in the truck if you take a reading at the generator on the 14v or 28v post to ground it should have an output voltage if it's working. Can someone please help?
