5 ton gas (OK fuel) pedal sticks
Tacitus
13
Virginia
I'm new to military trucks, had old pick ups for years. My fuel pedal sticks at where it's pushed down to. I can pull it back up by hand. I have sprayed WD40 on the bottom of it where it's attached and pivots, hasn't helped. So before I screw up something, anybody else had same problem? Solutions? Thanks for the help in advance.
porkysplace
1,493
mid- michigan
Are the return springs in place ?
You may also want to include what model 5 ton.
And update you location with a state .
74M35A2
330
Livonia, MI
I tightened up my return spring, and lubed the bellcrank mechanism on the engine side of the firewall. Been fine since.
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
If you have an NHC250 and the bolt that goes thru the clevis that holds the splined arm on it will cause a pedal lockup.
Sent from my SM-G935P using Tapatalk
BEASTMASTER
142
Burgaw, N.C.
yep ,I had that problem. the only way to FIX it is to take the pin out ,file it up real good,and run a drill through the hole in the pedal. use never sieze when putting it back together.
USAFSS-ColdWarrior
Chaplain
5,848
And update you location with a state.
I guess you missed this in Porky's previous post.
The specific model of 5-Ton will yield for you better answers.
Some folks probably haven't replied for lack of specifics.
Correcting your profile location is a SS Website RULE.... Please update it.
Thank you.
