Ecscnvb
- 1
- 0
- Va beach/va
Ticking from fuel tank. Any ideas?
Sent from my SM-G935V using Tapatalk
Watt?Lift pump is getting weak. Mine was doing the same thing on my 12 valve Dodge for about the last 15k miles of its life. My A2 was doing that when purchased so I replaced the LP and it went away.
This is what I was told at Cummins NW when I took my 12 valve Dodge for service. Sure enough the LP died not too long after. When replaced, the ticking stopped. I replaced the pump on my A2 as preventative maintenance and it also went away. I was told that it's the spring in the LP getting weakWatt?
Whats the theory on this?
Mine makes the happy sound of extra fuel, vigorously retuning to the tank at idle.
Weird cause my is less than a year old but I might change it to see if you are right...This is what I was told at Cummins NW when I took my 12 valve Dodge for service. Sure enough the LP died not too long after. When replaced, the ticking stopped. I replaced the pump on my A2 as preventative maintenance and it also went away. I was told that it's the spring in the LP getting weak
