aleigh
- 52
- 48
- Phoenix, AZ & Seattle, WA
I think tomorrow I'll rig it up and crack the lines and I guess we'll just see. And then I'll rebuild the manifold.
For Clarity is this what your saying?..Mine finally started working after switching the cab valve bake and forth from up to down and using the manual pump handle to build up pressure each time before switching. I thought I was never going to get it down and then suddenly it started working again.
Good luck
HiThread should be renamed to FMTV/LMTV hydrolifts + coolant so one day it can be found again. Those really good pictures will be hard to find. Those good photos at https://www.flickr.com/photos/advent...57669897327435
will be gone too?
0818 localHi
As of 7:42 the link above would not work. Cheers Phil
