rustystud
- 2,801
- Woodinville, Washington
Over the years people have tried to figure out a simple and cheap way to help lift the Deuce's rear tailgate. A few years ago some said "why can't we use springs to help assist it". The idea got shot down because some said it would not allow the tailgate to fully open. At the time I was still able to lower and raise the tailgate by myself easily. Now I've come to the point in my life where that is not possible anymore, so I decided to revisit this issue.
At first I had some issues with the choice of springs, but after finally finding the right spring I think I have solved the problem.
These pictures show my first attempt at this. The springs where not strong enough, but it showed me that the tailgate would lay down all the way with springs !
In picture two you see a little jig I used to drill out the cotter pin holes. I learned this during my years as a metal fabricator. You take a simple piece of angle iron ( like a 1.5" X 1.5" ) and tack weld a small bead on each end. Then using a level or "T" square you make sure the sides are perfectly level with each other. Then you weld a "brace" across one end. When you put this on a drill press you align the drill bit to hit the center of the groove and adjust for distance from the end plate. Now every time you put a piece of round bar in it and push against the end plate you will drill a centered hole every time on your round bar or tube.
Picture three shows the tube I used to take up the space in the spring and it also acts as a bushing.
Now these last pictures show the winning combination ! After searching for a few days I found some true "180 degree" springs that had a 3/4" center that also were the correct "spring rate" . I also had to rethink my last strategy in mounting them. I still had a piece of 5/8" bar that was 24" long, so I thought lets go between two hinges instead of just one. I installed this one today. It still needs the cotter pin holes drilled and the inner spacer but I just wanted to see if it would work. With just one spring installed I was able to lift my tailgate with one hand !
In picture four you can see the tailgate doesn't fully drop to the bump stops, but just leaning on the tailgate brings it up against the stops (picture five) . I need to buy more stainless steel round bar and tubing for the other side. I also plan on changing out all the side pins with the stainless steel ones too. No more rusted up pins for me !
I'm still fighting pneumonia ( for the last three weeks in fact) so it might take a little while before I finish this little project. There still is snow on the ground around here and the cold wreaks havoc on my lungs.
I had originally planned on installing a hydraulic cylinder with a set of funky brackets to raise and lower the tailgate, but it would cost a bit of money and time and make a simple operation (raising and lowering the tailgate) into a "Rudd Goldberg contraption" . This is much simpler and a whole lot less money ! Plus I don't need power to work it.
Now this is just a start for others to come up with their ideas. If enough people put their minds to this problem we can come up with the "perfect" solution !
For now though this will work for me.
